Edge Pulsar Questions from NEWBIE
Bill Traver
Central NJ
Just bought a slightly used 2019 that came with an Edge Pulsar unit on it. I am not a huge engine guy so I looked up what this was as I was getting an ELECTRONIC THROTTLE error at times when starting or driving. It does not come up all the time but occassionally. When I took it to Dealer (warrenty??) they informed me of the Pulsar unit and did not want to work on engine. Sooooooo, what have others done about this situation?
Also, If I take this off (which I think I can to get back to a stock set-up), are there covers or something I need to get to put over the two connection points? Where would I obtain? Could I just remove, drive to dealer, and ask them to cover?
Thanks for your patience.
Smilin Bill
Scott L
Rhode Island
2011 & 1998
HEMI & 5.9
Mind you this is coming from someone that just put one in 3 weeks ago but I think I can answer your question.
The pulsar is plug and play. The only difference with it on or off is the length of the 3 bolts. Disconnect negative on the battery. Then unplug the two (color coded) PCM plugs from the Pulsar, Remove the 3 bolts that are securing the pulsar and PCM in place. Remove the Pulsar and replace long bolts with 3 factory bolts. Plug cables back into PCM. If the factory bolts aren’t in the glovebox or something it may require a trip to Home Depot. Leave negative off for at least 30 minutes more to reset the computer. Hope that helps. Good luck.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Although after installing and removing the pulsar numerous times for dealer visits and such I never waited any extra time after messing with the pcm.
Disco battery, disconnect or connect pcm, connect battery and away you go
B
Bill Traver
Central NJ
Thanks for the replies, sounds simple enough .... BUT ... I have no factory bolts AND I do not have the factory PCM CABLE. I am new to the whole RAM experience ... is there any place better than others to get those cables (and bolts)?
Thanks
