MarcusP84
- Feb 3, 2019
- 12
- 1
- Location
- Central Wisconsin
- 2010
- 5.7 Hemi
Is anyone running this? Was thinking about getting one for my 2018. Any issues? Notable gains?
The ones for the 6.4 have been hit or miss. Honestly until they work things out a bit more I would stay clear for now. I do recommend a Pedal Commander. I have one on my Power Wagon and love it. Throttle response is awesome and being able to adjust it as needed is a nice bonus. Plus the truck feels much faster.
You can find more info here
https://gotexhaust.com/i-23645471-2...ottle-response-controller-pc31-bluetooth.html
Then use promo code PC5 at checkout for a discount and free shipping!
Also might want to check this solo muffler delete pipe out to make it sound as good as it looks!
https://gotexhaust.com/i-23646761-s...nce-muffler-delete-replacement-6-4l-hemi.html
For the PC it kind of varies for each person but sport 1 or 2 are the most popular for daily driving. For towing I would bump it down to city 2 or 3.
the delete will still retain the large resonator which is more like a small muffler. So its not too loud while cruising and at idle but gets rowdy at WOT.
For removal loosen the front clamp on the muffler. then spray soapy water on all hangers from the muffler all the way back to the tail pipe. Take the rubber hangers off that are on the muffler section. Then spray some penetrating oil on the 2 slip fittings for the muffler. then go to the tail pipe and pull back on it. I actually laid on my back and pushed with my foot on the rear tire while i pulled. it should come off. I recommend keeping a floor jack under the muffler so when it slides out of the pipe it doesnt fall and slam the back side of the exhaust into the bottom of the truck. Then loosen the rear clamp and pull that side off.
How's the 50 HD at highway cruising speeds? If got a Magna Flow on my PW (don't remember the model) and feel like it's gotten less aggressive sounding in the last couple months.Just ordered. $285 shipped. Hopefully I'll like it. Already chopped the exhaust but I took off resonator and added a flow master 50hd. I like it
Lol. Nah, def not used to it. I've had this exhaust for over a year now. It's literally been the last 2 months where I've noticed it. Quieter on start and and when I mash the skinny pedal. At highway speeds I had minimal drone when it was installed and now there's absolutely no drone.Probably because you are used to it LOL.
But drone is tolerable at highway speeds? All I've found for sound clips are 1500s and 2500s with the 5.7, I'm sure there's a slight different with our 6.4s.Still have plenty of sound when I get on it. Which is what I wanted. I will say that yes I notice a difference with the pedal commander. But not a $300 difference. I only use sport mode not the plus and yes it takes away lag....that's about it. If this was $149 I'd say this is great....300 eh it's ok. I paid 400 for my exhaust work and that was a better improvement in my opinion
[/QUOTE]Yup. Resonator is deleted.[
Did you delete the resonstor.....mine still sounds good and it's been about a year....dont make me worry man.....
QUOTE="Odin, post: 2061882, member: 27971"]Lol. Nah, def not used to it. I've had this exhaust for over a year now. It's literally been the last 2 months where I've noticed it. Quieter on start and and when I mash the skinny pedal. At highway speeds I had minimal drone when it was installed and now there's absolutely no drone.But drone is tolerable at highway speeds? All I've found for sound clips are 1500s and 2500s with the 5.7, I'm sure there's a slight different with our 6.4s.
