Edge Racing 11" Converter, 2600 Stall
theviking
Finally got around to installing the Edge torque converter I purchased from Matt (Moe's) back in April. Went with a 2600rpm stall since I tow occasionally and didn't want something I couldn't drive smoothly when needed. Matt did indicate that if I wasn't towing he would recommend a slightly higher stall.
Even with the 2600rpm stall it's a HUGE improvement over stock. So much more fun than the stock junk when accelerating from a stop. Trans also feels a bit smoother in general, although I did swap pans and change the filters at the same time. As a bonus, the shudder under load in first has disappeared as well. No ill manners at highway speeds that I can detect so far. Will be curious to see how if feels when towing.
Full throttle from a dead stop with TC off usually results in some combination of wheel spin and mild wheel hop. Put a load on the converter in 2wd and it will leave long sets of tire marks:) Best result was using 4wd with a slight load on the converter. No tire spin since its in 4wd and the truck just launches hard! Best 0-60 result was actually still about the same as my prior best, but this was in 70 degree humid weather and the prior best was done in sub-zero temps. I have no doubt this was worth an honest 3-4 tenths over the stock converter. For $550 it was money well spent, even with the 5 hour install factored in.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
One of the best mod's I installed in my 13, second only to the tuner.
Jay
Underarock13
Ram 2500 14
6.4 hemi
Hell yeah! Sadly this will be one of my last posts. Sold my 6.4 today and went to the dark side.... Darker then just a diesel.... 6.7 ford. So now selling my I tune Diablo if anyone is interested in it.
ksonnen1
florida
How do you like that 2600 edge converter with towing and how much weight?
theviking
theviking
Still one of my favorite mods. No issues towing and I've pulled some heavy loads over the years. I really can't think of any downside/quirks at all.
RamminMopar
How would a 2400-2600 stall compare to stock?
So about 1k to have it installed?
theviking
theviking
I would not go under 2600. If anything, might have tried 2800 if I was doing it all over again. According to Matt (Moe's) 2600-2800 is the sweet spot for a truck when you're frequently towing.
Night and day compared to stock. With the factory converter it always felt like some sort of torque management was active. The only way I could get a decent launch would be to brake stand the truck a bit. With the converter it just launches. If you perform a brake stand now it just fries the tires once you release the brake.
RamminMopar
SWEET! So converter with 4.56s should be fun lol
Terry3blue
6.4 hemi
What other mods do you have for the trans. Thinking about doing a stall but didn't know if I needed to upgrade anything else? I do have a hemi fever tune.
Lowrider357
