electrical problems
bleuboy
5.9 Turbo diesel
Help! This started a few weeks ago, when I would turn on the ignition switch on everything looked ok for a moment, then the air bag light would come back on and windows won't work fan won't work and speedometer won't work. the engine would start alright. Now even the engine won't crank. Changed out switch nothing changed.
When I turn on the ignition all seems well, but then the air bag light comes back on and no power to the windows or fan or starter. Help me out
HemiSport07
Central FL
Idk somebody should chime in but I'm having the same issue with my airbag light have you tried resetting the computer?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
short or a blown fuse maybe?
B
bleuboy
5.9 Turbo diesel
Checked all fuses. Shows no codes, could not find any shorted wires. I am at a loss
HemiBabe
DFW
Wow, sounds like a wiring problem... bump for anyone who may know
HemiBabe
DFW
I would try a computer reset and if that doesn't work it has to be something in the wiring harness I would assume
