Electronics and more
Status
Not open for further replies.
RedFalcon
Katy, TX
So, I realized the other day that I have some extra stuff left over from projects and such. For now, I'm looking to try and keep everything local. I'm located in Houston, TX and I'm willing to drive within roughly a 3 hour radius of Houston. I may consider shipping some of the smaller/lighter items on buyer's dime. I am open to offers.
The next few items are from a 2008 Dodge Ram 1500 Quad Cab.
I have a fog light setup that I ran for a few months before I traded in the truck. The lenses are smoked and comes with halogen bulbs. When I had it installed, I swapped some 9006 LED bulbs in there and really liked the look. Looking for $50. Comes with halogen bulbs, fog light housing, relay harness, and switch.
Next is an Alpine CDE-121. Radio works just fine. Comes with the dash kit and antenna adapter. $40
Alpine KTP-445 Power Pack. Quite literally a plug and play amp designed for 2005 and up Alpine head units (with the exception of the CDE-100). No amp kit needed. It plugs into the back of the alpine unit and the other end plugs into the alpine wiring harness. $70
I have a set of Cadence FS5525 coaxials that ran in the back doors. $20
This is a license plate backup camera that was used on a 2009 Dodge Ram 1500 Quad Cab for 2 years. Shows some wear and tear but still works great. Comes with brand new wiring for the camera. $20
The next set of items come from a 2010 Dodge Ram 1500 Quad Cab that I had for roughly 6 months before it was traded in.
Bayou Goat Mount (BGM005) Dual Disk Dodge Tray meant for 2009- early 2013 Dodges. Only used one side. Still have the template for the rubber cutout. $20
Pioneer TS-SW200D2 shallow mount free air 8" sub. I absolutely love this sub. This is actually my third one. When I was looking to upgrade my 2010 Ram with alpine system, I bought another. I swapped the subs and had the pioneer in for a week before I put the stock sub back in. The pioneer sounded terrible with the factory enclosure without an aftermarket amp. $50
These next items were never installed for whatever reason and are brand new still.
This is a Rearview LCD Mirror with a 4.3" display with 2 inputs. One input is for a reverse camera and will auto switch when the camera receives power. You could use the other input for a front camera or whatever you want. This is NOT an autodimming mirror. It will autodim the brightness of the LCD, not the mirror. This mounting bracket should fit any Dodge or Jeep but I'm not 100% sure of that. I would compare the mounting bracket to yours if interested. This was never installed. Bought it for my 2010 Ram but never got around to installing it before I traded in the truck. $65
Hella Supertone Horns B133 Series. Was going to install these on my other car, but went a different route. These are normally red, but I plastidipped them gold. I can remove the plastidip if desired. $35
I have (2) 12" Autotek ATX12D4 subwoofers and a Crunch GPV1100.2 amp from an install that never happened. Looking for $65 each for the subs and $60 for the amp. Or $115 for both subs. I'll sell the whole set for $150.
I also have a set of 4 OEM 17" wheels + tires from a 2009 Dodge Ram 1500 Quad Cab if someone's interested in them. Looking for $400
R.L.K.
Bristol , Tn.
Could you please post pictures of the 17" wheels and tires Sir ?
Also how wide are they ? Backspacing , offset ?
Do they have ANY curb rash ?
Please get the tread depth in the tire pictures .
Thanks !
RedFalcon
RedFalcon
Katy, TX
I'll try and get some stuff about the 17" wheels ASAP. They're actually at my friends house. All the rest is in my possession.
RedFalcon
RedFalcon
Katy, TX
Threw a few pics of the 17" OEM wheels up. Should be just usual wear and tear on the wheels.
Status
