VA-RAM
- Nov 17, 2019
- 166
- 106
- Location
- STL, MO - Norfolk, VA
- 2017 Laramie / 2020 Laramie
- Hemi 5.7
So...
Looking at getting some new (to me) wheels and tires on the 2017 1500 Laramie. Been doing some research and have run across a term called scrub radius. Never heard it before.
What I am looking at (KMC XD779 Badlands, 20x10 with Fuel Grippers M/T 33x12.5x20 and a -12 offset) will fit according to the wheel/tire calculators with, I believe, is enough clearance of the brakes and UCA. The calculators say that there will be a Positive 1.25" scrub radius with this set up.
https://www.wheel-size.com/calc/?wh...l=1.96875in&wcl=1.1875in&scl=1.96875in&sr=0in
The stock 20" Laramie wheel and 275/60/20 tires (19mm offset) tires show a ZERO scrub radius on the calculator. I don't mind the tires moving out about 2" (with the difference in OEM vs XD779 offsets), as I intend to do a front lift of about 2" anyway in the near future...
The question for the forum and for discussion is:
What is "too much or too little" scrub radius ?
What affect on braking and handling will the 1.25" positive scrub radius have on my Ram?
What is the prevailing "ideal set up" (if there is such a thing) for the 1500 Rams?
Ultimately, will this set up leave me pissed off at excessive tire wear and reduced ride/handling?
ready, set,...GO!
ready, set,...GO!
