Be-Still-My-Dodge
Turning or going over little bumps or big bumps my truck makes a horrible noise which can be heard blocks away. I've replaced all the upper and lower ball joints and the noise is still there. The lower ball joint is defective so I have to replace it again, but I cant believe that is making all the noise. I've heard sway bars, and sway bar bushings, can you get by with just the bushings? Or does it come in a kit?
what brand should I buy if I replace the sway bar busings and the end links?
