BearlyFunctioning
- Apr 6, 2016
- 25
- 7
- 2017
- 6.4
I have a 2000 ram 1500 5.9 gas.
After being warmed up it dies without warning while driving.
NO spitting, sputtering, surging or popping. No change in instrument cluster EXCEPT within 3 sec the speedo then also quits at highway speeds. The tachometer still reads some rpm's (truck still in drive). The code NO BUS used to show up in the odometer, but that has stopped showing up.
Sometimes it will start right back up after turning ignition off, even while still rolling down the highway.
Other times it happens while going slow enough you must pull over. It will either start right back up OR take up to 15 min to restart.
When it does restart immediately it starts normally. If I have been cranking it for a while trying to get it to start it seems to start sluggish for the first 1 or 2 seconds then runs normal, never any spitting, sputtering or popping.
Already took it to the dealership, their diagnostics said replace coil. I replaced the coil with no change. They also said there were NO codes at all in the system
