Engine swope from 5.2 to 5.9
Eddiedatruth7474
Arkansas
I swooped my 5.2 to a 5.9 engine in my 2001 dodge ram. Can I use the same transmission that was already in the truck.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
yes, should be a straight bolt on.
Nealuss
5.2L 318
trans is the same but the torque converter is different due to balancing.
Wahrsuul
Central S.C.
We did the same thing in reverse, swapped a 5.2 in place of a 5.9. The torque convertor is the same, but the flywheel is different.
Yeah, I know, we didn't know what was in the truck - the decal on the front crossmember said 5.2, so that's what we got. Wasn't till we swapped it out and had bad vibrations that we found out the flywheel is different and that we'd had a 5.9 in there to begin with. Swapped to a 5.2 flywheel and all is good.
