cptwing
- Aug 14, 2014
- 1,446
- 497
- Location
- The Soviet State of Connecticut
- 2014 3500 ST DRW REG CAB
- 6.4l Hemi
I made up 5 of these to clear the error message when upgrading the third brake light from incandescent to the OEM LED. When you do this you will get a brake light out error message in the EVIC. This device which is pure PNP no splicing or wire taps, fools the computer and you do not get the message and it does not use resistors to do it. Note: When you get the third brake light out message it shows the pass brakelight out in the graphic on the EVIC.
I am selling the remaining two for 25.00 each shipped. If you added an aftermarket LED third brake light and are also getting the error this should also work for you as well, provided it uses the same OEM plugs.
![DSCN0831[1].jpg DSCN0831[1].jpg](https://www.ramforum.com/data/attachments/53/53685-db0f2f164375ef8375369bbec15ec09e.jpg)
Here is a screen shot before installing. Ahh Error message!
![DSCN0660[1].jpg DSCN0660[1].jpg](https://www.ramforum.com/data/attachments/53/53686-ef6c92b5cc9db2b437feb1ef7b3a5852.jpg)
Here is a screen shot after installing. Error message gone!
![DSCN0668[1].jpg DSCN0668[1].jpg](https://www.ramforum.com/data/attachments/53/53687-4ea80f1779be3ee553f50e9db45b1538.jpg)
