corneileous
- Sep 6, 2016
- 7,139
- 4,143
- Location
- Podunkyville, OK
- 2018 Ram 1500 Limited 4X4
- Hemi 5.7
Hey guys, on my ESC, I just learned a new trick that I didn’t know I had. Of course, I knew that when I shift my transfer case into 4-LO that not only does it automatically disable the auto park that slams the transmission in park if you drive with the driver door open and the seatbelt is not buckled but it also turns the ESC off but I had no idea that when you shift into 4-LOCK that if you press and hold the traction control button, after a little bit it’ll say across the screen behind the steering wheel that the ESC has been disabled.
I know a little bit about how the ESC works, but when the ESC is turned off in any of the four-wheel-drive modes aside from four-wheel-drive auto mode, what exactly is taking place with the ESC off? It would sure be nice if by, turning the ESC off would actually take away the constant engaging and re-engaging of my front drivetrain like it does in auto four-wheel-drive but I kinda have the feeling the transfer case is still gonna do that whether the ESC is on or off. If I had some snow outside to play in I could certainly go out and test it on my own but I highly doubt we’re gonna get any snow down here in southern Oklahoma anytime soon…lol.
But anywho, in regards to the bulb out message on the dash screen, I’m fixing to reinstall my security module bypass cable so that I can run my Alfa OBD program to see if I actually changed the license plate lights to LED being that I can’t remember if I did that or not and being that I also can’t remember where the bulbs came from that I put in my license plate lights to see if they actually are canbus compatible but the other day I noticed that one of my license plate bulbs was burnt out but I never did get the message on my screen saying it was out so how do you, or is it even possible to use LED lights in whatever socket that’s incandescent but not have the light out message show up when it’s not supposed to but actually make it show up when one of the LED replacements quits working? Thanks.
