ESIM gasket
Michael Speer
NY state
Replacing ESIM gasket is it ok to put 2drops of glue to hold the gasket in place ?
rzr6-4
nebraska
'09 2500
You would be best off with a type of glue that will be resistant to the solvent properties of gas but other than that I can't think of why it would hurt.
Michael Speer
Michael Speer
NY state
Just did mine took 10 mins At the back of the tank behind the heat shield it’s a little white plastic module pull out the electric plug, pull off the air hose there’s a black tab on the bottom of it push the tab and turn the module counterclockwise will come off remove it and the gasket put a new gasket on put the new module , you will feel it line up , push in and turn it clockwise to lock it in ,straight up and down, connect the hose and the plug , it’s tricky to get at the tab and push the tab in and turn the unit at the same time
