Estop disable
WSix
S. Illinois
I've not seen that device.
I believe if you manually select 8th gear with the selector, or put it Tow Haul, it shuts it down.
CRS1968
Edmond, OK
Or just push the button to turn it off. Not a big deal. That said, it’s pretty smooth in my 2023 Limited. Don’t notice it much at all.
There's a couple of those devices on the market, they all do the same thing: retain the last setting of the "Start/Stop" switch as it will reset to On every key cycle with module.
This is another manufacturer:
DanAR
Arkansas
2023 here. My salesman pointed out the temp disable button at pickup but then went on to say something like, it may cause your battery to discharge. I think he was winging it. :rolleyes: It doesn’t bother me that much.
joshhhh
