Exhaust Install Tomorrow, Still on Fence with H vs X
LilRamie
Atlanta GA
So I'm slated to have my new exhaust mods installed tomorrow and cannot get 100% comfy with my decision on the mid pipe. I'm currently leaning towards an H pipe in lieu of the X pipe.
Here's my basic limited knowledge on the selection.
Both are good choices as opposed to neither. X is considered more efficient with scavenging and will therefore give more HP but its only realized on the High end whereas the H will help with back pressure and give more Torque on the Low End. X has a more modern / european raspier slightly quieter tone whereas the H has a more musclecar /old school deep throaty growl tone.
Assuming the above understanding is correct then I'm on point with the direction of my selection towards the H. Currently I'm pleased with my trucks higher end, in fact I'm quite impressed with how much more it has in reserve at say 65mph when you just touch the gas but I'm not nearly as impressed on the lowend even with 3.92s on the 8spd. If I'm already moving at say 15 or 20mph and punch it I would have though it would be lighting up the stock skinny wheels but it doesn't perhaps b/c track control but don't see more torque on a truck as a bad thing :).
On the sound side of things the muffler I have selected (Borla XR-1) it already gives me the tone I like. So with an X I don't want that poppy or as I call it the modern fart sound on the flip side I don't want to enter the overly drone possibility If I add in an H but that's part of my ignorance I suppose hopefully it just enhances the nice growl and not the drone.
Also my in my ignorance I understand the X to be a better choice performance wise but not significantly so on a % basis when comparing apples to apples.
So any wise words of wisdom and insight towards the X vs H debate are greatly appreciated. Also most of what I have found on the subject in my newbism has been non vehicle specific so feedback specific to Ram with Hemi in mind would be great!
zavaral
OKC and Elgin TX
I have always like H better. Dont know why but ways prefer H
Sent from my LG-D851 using Tapatalk
MADDOG
Living in a Firepit
The H would be my preference.
I want more low end with sufficient exhaust scavenging and since most of my driving is well below higher RPM range, the H provides benefits I will use for most of my driving.
L
LilRamie
Atlanta GA
here's an example of what I meant by the modern fart in an Xpipe vs the growl desired by an H pipe on an apple to apple comparison on the same vehicle even though its totally different than my ram :)
https://www.youtube.com/watch?v=d1m3xfIZDkE
comparing around the 40sec to 1:13 mark to the 2:45 to 3.09 mark or so.
I also found these on the same ram but with it being cammed etc I thought that it was a unfair comparison but boy does it sound good :p (gotta believe its loud on the inside too tho, maybe to much for daily :(
https://www.youtube.com/watch?v=Y9pFJaODAKg
https://www.youtube.com/watch?v=wHKy_B53ZDw
I cant help but wonder whats the dyno difference on these not just the high end but low end as well...
R/T_Fire
Pleasant Grove
Damn that thing sounds mean.... I want to hear it get on it...
But one thought I was having is does having a equal length system from right to left banks make a difference since driver side has to cross over to passenger side to clear the fuel tank?
Boulevardvette
Not sure about the performance aspect but I would almost bet the H will have a better sound.
L
LilRamie
Atlanta GA
Well just dropped off, going h pipe
Sent from my SPH-L720 using Tapatalk
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
+1 I would like to know about equal length system too. Balanced exhaust systems pulses seems like it would be best. But, I'm no expert.
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
hmmm... wasn't aware anyone was running an H around here!
L
LilRamie
Atlanta GA
Well I am now... Just got back from a late lunch break. The guys did a great job. I'll be sure to upload a lot of good pics to photo bucket and post when I get home from work this evening... So stoked!
L
LilRamie
Atlanta GA
Oh yea need to make some of those too. What do you guys use for splicing videos together?
14hemiexpress
6.4l
I like windows movie maker it's pretty simple to use.
L
LilRamie
Atlanta GA
I will once I have access at home, can't do at work. One thing I had them change is how the stock pipe crossed under the tranny. I didn't like that extra heat coming from the pipe right under it. Not to mention it was right in the way of the tranny drain plug.
I was also surprised by the old pipe itself leading to that restrictive stock y everyone complains about. I got a pic but the top of that pipe was also factory crushed, I presume for clearance at the tranny...
L
LilRamie
Atlanta GA
TheDonVon
The mufflers you got were 3" in 3" out? So i assume you ran 3" pipe out the back? Also are the headers 3" pipe? Or did the shop need to adapt from 2.5" to 3" before the mufflers? Sorry if the pictures show this (I am at work and cant see the pics).
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Looks like you cleared your tranny from looking at the pics. Great idea if you ever need to pull it, well done:favorites13:
ChloeBrooks
