exhaust problems!
nim81
Fredericktown, MO
5.7L
from about 2000-2500 rpms my exhaust makes the WORST rattling noise! ive been under the truck at least 4 times have completly went over every inch of the exhaust and everything is good, no visual problems, even grabbing ahold of various sections of the exhaust and shaking, kicking, hitting... everything seems good. but my god the rattling is soo loud when going down the road..
anyone else have this problem or have any ideas what could be causing this?
been happening for about 2 months now and im at wits end.
any info or advice would be much appreciated!
glass3222
Central PA
What kind of exhaust do you have? Sounds like it might be a broken baffle inside the muffler.
nim81
nim81
Fredericktown, MO
5.7L
si/do chambered magnaflow.. is that common? ive had a magnaflow on every vehicle ive owned with no problems. never actually heard of that happening.
nim81
nim81
Fredericktown, MO
5.7L
hmm.. i guess a couple minutes with a reciprocating saw and i could find out
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would use a rubber mallet and smack the pipes and muffler to see if it rattled.
nim81
nim81
Fredericktown, MO
5.7L
ive gotten under the truck and kicked (with steel toe boots) and banged on various sections of pipe including the muffler and cat with no rattling .
i really dont want to but im seriously thinking of chopping out the muffler and see what happens.:superhack:
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Could you be mistaken for a bad U-Joint!
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Thats good man, Only asked cause it happened to me with one of my Fords it sounded like someone was banging/rattling on a tin can or a heatsheild was loose no bang when put in gear and was only at a certain RPM.
kicker417
galveston,tx
i have the same problem with mine i just gave up on it could never figure it out what it was and my truck 2008 4x4 hemi qc
pavester
texas
maybe the 02 sensors? i know i had a bad rattle and found it was one of the 02 bungs had wiggled its way loose and at certain rpm's it would vibrate making a horrible metal on metal noise
Redtruck-VA
Virginia
Maybe, something like a loose bed, bumper, trailer ball? Beer cans rolling around... Impossible to tell.
Torque
Colorado
I had the same noise with the OEM muffler when my truck was a year old. 500 rpm band around 2000-2500, rattle rattle rattle. Wouldn't do it as much when the truck was cold, but warm and when i was slowly getting up to speed, it'd rattle like a sob when it past thru those RPM. It was around the same time i was shopping for a better exhaust so i hoped it would cure the problem (and it did) with a new muffler.
nim81
nim81
Fredericktown, MO
5.7L
well that settles it im cutting the muffler off tomarrow! will keep y'all updated. thanks for the help!
nim81
nim81
Fredericktown, MO
5.7L
ok i cut the muffler off and it was broke on the inside... no more rattle!! on the down side i have to order a new muffler now cause nobody around here has a si/do anywhere so im thinking about running a 24" resonator... as of now i have no muffler .
garner
Harker Heights, TX
Could just dump it where it's at
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
nobody has a muffler down there? thats nuts!
glad you found the issue though!
nim81
nim81
Fredericktown, MO
5.7L
well i have everything already set up with dual outs with real nice magnaflow tips, i like the look so i was just going to run a Y off the resonator ...
ya im down here in the woods man! nobody has anything around here!!!
Agcat
