Exhaust Warranty Question 2010 w/ 6.7 CTD
SNOWMAN
Larkpsur
6.7 CTD
My truck leaks exhaust into the cab. It's coming from the rear of the turbo straight out of that clamp. I suspect the donut is broken and therefore not sealing. The truck has 44K on it. Does anybody know if this is something Dodge or Cummins would cover? Everything else works fine.
Thanks,
Stangshcky12
Oshkosh, WI
5.9 Cummins
I would think that would be under the 5 year/100k mile warranty
Welcome to the forum, looks like you have a lot of fun with that 3a!
jlb
MT
CTD
Definitely covered as it is a "mechanical" part which is what the 5yr/100k powertrain warranty covers
NWRQC
Thanks,
There is no exhaust donut on the connection between the turbo and down pipe, it's a V-band clamp. Check to make sure it's tight, it might be loose for some reason.
