Factory plastic bed rail covers
SwollenMonkey16
So I want to get a spray in bed liner and I just found out they can't replace the factory plastic bed rail covers with line x due to the fact that it's not solid metal underneath, is that true? Does anyone have anything different covering the rails other than the normal plastic
BigA
Ohio
5.7 Hemi Etorque
correct, their are holes and the sheet metal is cut for the plastic covers so you would not want to take them off unless you have some other cover which they may make.
Rlaf75
East Hartford CT
2021 Bighorn
You can take them off, get the truck sprayed then when you get home locate the holes and clean them out with a razor blade or whatever so you can pop them back on. Or just don't have them spray on top of the bed rails
Mineralram
For the love of god dont spray the rails it looks so cheesy and cheap afterwards
Sent from my SM-G900W8 using Tapatalk
joshhhh
