Fan Swap
Ram1958
Carstairs AB
Considering swapping out my stock fan and shroud for an Electric Set up. 2017 1500 Crew 5.7 Hemi.
Any thoughts on this or ideas/advice? I know I will need to install temp sensors to control fans( looking at a dual setup). Cold Alberta Winters, Hot Alberta Summers.
grizzstang
Calgary, Alberta Canada
There are several good threads on how to do this. Your truck already has an electric fan as well as a mechanical fan so many remove the mechanical fan and upgrade the electric fan to the V6 Ram electric fan as it pulls more cfm. Then you would need an unlocked pcm and a tuner to adjust the electric fan temp settings. Do a search for more details and welcome from a fellow Albertan.
