Fantasy Race 5.7 hemi vs 6.0 powerjoke
Farmer888
ontario
Ok so a friend of a friend has a 2005 6.0 powerjoke. Apparently it's pretty quick and I do believe they are decent especially moving a F250 around.
Not sure on his gears and tires etc but lets say both are pretty much stock, I have 3.92 gears with 17" rims 1500 his is F250
My 2003 5.7 quad cab 4x4 vs his 2005 6.0 4 door short box I believe 4x4. Who would win?
I know it's easy for a modified diesel to kill a gas, and how easy it is to add big hp with just a tuner to a diesel etc. But stock for stock other than maybe exhaust and intakes. I would like to think I could take him but not actually going to race cause of the consequences of cops or an accident etc.
HemiLonestar
Navy Badge Coast Guard
MD
Stock for stock, you have the weight and possibly gearing advantage. Both of you can launch in 4wd to negate traction issues. Be fun to watch, in the end it may just come down to driver mod lol.
Karlsweg
SW Florida
Probably a photo finish if he spools up at launch.
F
Farmer888
ontario
Ok yeah looked at the specs of a 6.0 for 2005, 325 hp @3300 rpm and 570 lb ft @2000 rpm
Pretty impressive although I'd never own a power stroke much rather have a cummins for reliability or even a duramax.
I'd be a lot lighter than him and I think he has 3.73 gears.
Goddard KS
The tuners alone on diesels will give 100, 150, 200 hp.. and more depending on intake, exhaust and other things.. I believe the 6.0 was bad about head gaskets.. he may never make it to the finish line without a tow.. hahaha
GrumpyOleMan
South Dakota
As a previous owner of an F350 CC 4x4 w/ a bulletproofed 6.0 I can attest it is an exception motor ... for hauling and pulling its a beast. But generally speaking torque is for grunt work, pulling and hauling weight around and horsepower for 1/4 mile times. I would go with the 5.7 with its better HP to weight ratio.
Of course, all this is my opinion and subject to be wrong :33:
finally03gt
Houston, TX
Best I could find on the web....
SLT Hemi Regular Cab (6.3 ft. Bed) RWD 6.8 sec 15.11 sec @ 89.06 mph
2005 Ford F-250 Super Duty 4X4 Crew Cab Diesel 0-60 mph 10.0 | Quarter mile 17.5
F
Farmer888
ontario
Yeah for sure, Like I said in the original post I know how much power can be had on a diesel with a tune. I wouldn't attempt to go against a diesel with a tune unless I know he's a bad driver and probably lose traction on takeoff. I wouldn't want a 6.0 or even a 6.4 cause I don't want to have to bulletproof a engine just to use it normally.
F
Farmer888
ontario
Thanks, with me being quad cab 4x4 I'd probably be 16 something seconds? Anyone know the weight difference between a regular cab 2wd short box vs a a quad 4x4 short box?
My buddy has a 98 ss/t ram single cab short box 5.9 gas and it's really quick for a pickup of that age. even with 100 hp less he can keep with me pretty good.
Goddard KS
In your original post you said "stock for stock other than exhaust and intakes"
Exhaust and intakes on a diesel is 2/3 of the way done to 300hp added..
If you really wanna know who would win find out what your buddy has 100% in his diesel.. we cant help if he might have exhaust or might have intake or even might have tuner that you do not know of...
ST-8
Op your truck prob runs 16.0-16.5 stock a lot depends on where you live.
WilliamS
Tampa FL
A tuned diesel can be wildly fast. Heck the stock 6.7 Powerstroke is impressively fast with 950 torque. Dont underestimate a tuned 6.0 either, Ive seen them with 300k on the clock running high HP tunes that outrun v8 pony cars.
F
Farmer888
ontario
OK well just lets assume both trucks are stock and stock.
F
Farmer888
ontario
Yeah I know how wild they can be with just a tuner. I am familiar with Farm equipment diesels.. Same engine can be 130 hp in a tractor all the way up to 230 hp with just computer/ fuel settings.
MikeG71
U.S. ARMY '02 - '12
Cheyenne, WY
06 Mega 2500
@Farmer888 I wouldn't think it's even worth comparing. The 6.0 will probably blow the head bolts (which those P.O.S.'s were known for), so he probably won't even make it to the finish line.
At least not until he's hooked up to the Tow Truck..............:happy175::happy175:
chrisp2493
Always Modding
Warren, OH
392 Hemi
My brother has an 04 6.0, I have a 03 5.7 quad cab (your exact scenario!). We had two half way decent street races. First race he didn’t boost up and I got the jump on him off the line big time. Unfortunately I missed 2nd gear (I was manually shifting the truck) so didn’t get a decent full pull. Turned around and ran again, he boost launched and killed me. I had an intake and headers, 3.92 gears. I can’t remember if he was tuned or not though. Not perfect results but that’s street racing for you
I Bleed Ram Trucks
