FAST FIX for Common Problems Thread
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
This is starting a Fresh Thread to Quickly Find Solutions to Common Problems. It is not intended to be long-discussions….NO DISCUSSIONS… just a Fast and Easy Solution. Name the problem. Post the FIX! What made me think of this thread-idea is I spent considerable time trying to troubleshoot my Cruise Control….but stumbled upon the FIX in another Looong Thread …many pages later… and it was a Great, Simple, Quick FIX! So I wondered if this wouldn’t prove useful to others.
Post PROBLEM
Post FIX
Here’s my example (number One):
1- PROBLEM: CRUISE CONTROL….. ON Switch Intermittent or INOPERATIVE
Steering wheel switches no longer work.
FIX: Hold the + and the - switches SIMULTANEOUSLY for Ten Seconds to RESET and RE-BOOT Cruise Ctrl.
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
The ole: RAM IBS debate/How to Charge/Jump Battery, To reset/not reset IBS when replacing battery. From head mechanic at local dealership: When changing battery, pull IBS from rear small bolt for at least 2 hours. See PDF from RAM Star Case below. (Also helps to charge battery you buy to 100%).
  • IBS-10173323-9999.pdf
