Jsinclair92
My truck is full of fun surprises. When I fix one problem, another is quick to arise. I can't say I dislike that.. I mean it keeps me busy.
Problems:
- AC switches to defrost on WOT or when under a load (rarely happens)
- When i shut the truck off at night I can see condensation forming on the windshield above the defrost vents like it is blowing out with the truck off or something. I haven't used defrost in 8 months or more.
- With the AC turned completely off the vents still blow lightly. If the temperature setting is on cool, cold air lightly blows. If its on heat, heat will lightly blow.
- The truck has a pretty violent intermittent jolt. It usually happens at cruising speeds; the RPMs will quickly drop then shoot back up to normal. If the AC is on when this happens, it will stop blowing for a few seconds. It may switch to defrost but I have never slid my hand up there to confirm that since it happens so fast.
- Cruise control light will turn on but doesn't actually activate. In other words I cant use cruise control.
- I have power loss and a whine in first gear. Also trouble changing out of first gear. Instead of smoothly changing gears it will stop at a certain RPM and wait, sometimes up to 10 seconds or more, until it shifts to second. I have an automatic transmission. This may be a mechanical problem such as a clutch plate, but I wasn't sure so i wanted to list it.
Problems:
