Fatal flaws
pathvet
Long Beach
6.7L diesel
I call it a fatal flaw as my RAM3500 diesel has only 62k and has developed an oil leak that is originating at the timing plate. Should not happen on this juvenile diesel but it is Near fatal because it involves lifting the cab and engine to get to the area. And of course there is no warranty left for this.
So while I am at it and the engine is exposed, decided to fix some other flaws known to Dodge and Cummins. New solid lifters and a CP3 fuel injection pump.
It is amazing that my 2020 RAM was built in Mexico in January and Dodge/Cummins went from the flawed Bosch CP4 pump back to the tried and true CP3 pump
But of course did not tell anyone> sell more trucks that way. I THINK NOT
P
pathvet
Long Beach
6.7L diesel
this is a once venerable straight 6 diesel that can haul like a trooper when it is right
ramffml
ramforum
I think putting a v6 in anything larger than a sedan is a fatal flaw
I agree with that sentiment, but that cummins is literally used in busses and other heavy duty equipment, I think it'll survive the horrors of a little scooter like the Ram :)
diymirage
Banned
Sure, if we're talking Cummins, but I thought we were in the "v6 performance" part of the forum
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Moved to a more appropriate forum.
P
pathvet
Long Beach
6.7L diesel
Sorry to have posted in wrong section. I have moved the post. Thanks for your patience
nlambert182
Huntsville, AL
Don't know which of your posts will stay and which gets the can, so I'll respond to both.
They did...
"Owner notification letters are expected to be mailed out on January 1st, 2022. Owners may contact FCA US, LLC Customer Service at 1-800-853-1403. The reference number for the recall is Y78."
https://static.nhtsa.gov/odi/rcl/2021/RCRIT-21V880-5163.pdf
You don't have to lift the cab nor the engine to replace the timing cover gasket. It's a 1/2 day job at the dealership at best. Engine and cab stay in place. There are Youtube videos if you want to see it done.
At 62k miles though, I'd talk to Ram (nicely). Sometimes they may help you with warranty since it's that close.
Dean2
Near Edmonton
If your dates and mileage is accurate you still have power train warranty. Might as well use it.
stevenmicheal
