Finally did the Bilstein 5100's with a 1.4" level
Vinnie1986
New Jersey
What's up fellas finally installed the Bilstein 5100's front and back and man what a difference it makes! Was never a fan boy of Bilstein but man they ride beautiful on this truck. I Ended up doing a 1.4 level on the struts because I still wanted a slight rake and better ride quality. Here's some pics
hemiguyinMD
Maryland
I have read many reviews stating that different bolts / bushings are required for the rear and are not included with the shocks.
Did you encounter this?
hemiguyinMD
Maryland
Sorry for the late reply.
I ordered 5125s because my rear is lifted 2" They are considered "universal fit"
They came with bushings and sleeves for a 1/2" bolt and they are shorter by almost 1/2".
My Ram uses 5/8" bolts
Smaller bolts is a BAD idea because it will slip and clunk in the bracket (which is drilled for 5/8) inevitably wobbling into an oval and causing other problems.
I just removed the bushings and sleeves from my old set and pressed them into the new ones. Viola
