Picked up my 2022 Ram 2500 with the Firestone tires in October, first snowfall in Mich recently and I will say the tires are awful!! Couldn't even make it up my driveway without 4WD. They have to go for sure. What are you winter drivers using? I have had BFG A/T's before and had good success may head the route again, but looking for some real world applications. Thanks.
I have no experience with Firestone tires although the Transforce AT2 LT looks quite reasonable.
What pressure are you using? More about pressures below.
I've tried a few different dedicated winter tires & always come back to BFG KO2s. In fact, the last set of winter tires I tried out, I sold them after a couple of snowy drives, ate the loss, and replaced them with BFGs.
The same pressure on one type of tire might be fantastic and with another, a nightmare. Also, the performance of the tire could change dramatically on different trucks.
Tire pressure changes of a few PSI can transform how a tire performs in adverse conditions.
On my last truck, a Tundra, the door plate pressures were 33psi rear, 30psi front. I didn't like how the tires were wearing and experimented with higher settings. At 35psi on the rear with any amount of light snow, the rear would break free and spin. I'd get stuck on the slightest of inclines and require 4wd to get started. Those tires were BFG, KO1s, IIRC.
Now almost the same tire (BFG KO2 E-rated) on my Ram is a completely different story.
Most of my driving is highway and I usually use about 42psi rear and 44psi front and rarely have any slippage. If I were driving less highway, I'd drop those pressures a bit.
