Flashing check engine light.
Bcameron13
First time posting, I have an 06 2500 with the 5.7 which I have an intake and exhaust. My problem is when I go to floor it, randomly it throws the check engine light and flashes and beeps for a sec then when it does i let off and it will stop. I have no idea why, the trucks got 135 thousand miles so I'm leaning towards replacing spark plugs. Any suggestions?
B
Bcameron13
I havnt checked yet but I don't think that it will show any because the light doesn't stay lit.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
What does your oil PSI do when you do that? When the light is flashing something is very very unhappy.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
See if any codes are stored even though the light is currently off. When was the last tune up done? Does it drop power when this happens?
B
Bcameron13
I'm going to plug it in after work and we'll see what's going on. I bought the truck 3 months ago so have no idea when the last tune up was( if its ever had one period ) but I have 16 Ngk iridium spark plugs coming tommarow so hopefully that helps. I know when I first got the truck I ended have to replace the tranny solonoid and valve plate, and when the code came back for that it also came back with a cylinder 2 misfire, so that what I'm leaning towards.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
#2 could be a coil lead or the coil itself breaking down at high RPM. If it points to that one again yank a plug and see what it looks like and swap #2 with #1 coil to see if it fallows it before you dump money in a new coil. Its not as common but a faulty or going out injector can also throw that code.
B
Bcameron13
Thanks ken ill check it out. Hopefully ill get the chance to pull out the code reader tonight.
B
Bcameron13
Cylinder 2 misfire ( kinda figured) coil is good so got Ngk iridium ix plugs coming Tuesday so hopefully that'll do the trick.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Did you swap the coil to confirm the coil is good?
B
Bcameron13
Yea the coil was fine didn't fowl a plug, but the plugs look like they've never been changed.
yotamafia
Did you ever figure out the issue my buddies truck is doing same thing?
RonJon '06
Southern Minnesota
My truck is doing the same thing right now, turns out it's misfiring on cylinder #4 but only when the engine is under load. After switching coil packs and getting the same result I did a compression test which showed low compression on that cylinder.
