Flashing in a brake controller?
Micks-hemi
Abbotsford,BC
Hi Folk's:
Just traded my 2014 in on a 2016 and i love it! My question on installing a Prodigy brake controller is,can it be enabled on the evic or does it have to be a factory type of controller?
Thanks
Mineralram
Only factory works with the evic, and anti sway control when hooked to a trailer
Sent from my SM-G900W8 using Tapatalk
keithert
So an aftermarket brake controller won't activate the sway control?
Sent from my LGLS992 using Tapatalk
Mineralram
I have heard a few report that the sway control will work on the truck but not the trailer, it only works with the trailer also when using a factory controller
dennydodge
Davidson Co. NC / Cayuga Co. NY
I also use a Tekonsha Brake controller , Tekonsha Tech support told me the 2016 Rams Need a different adaptor harness. Part # 3024P. It has a diode in it to prevent damage to the brake system. I don,t know if I would use the one off your 2014. ,,, Just my 2 cents.
keithert
I just found my receipt for the brake controller plug and the one I have is the E3024-P. Good deal.
