Flowmaster American Thunder Leak
GMcD
South Carolina
I just installed a flowmaster and i am getting leaks at both outlets. I have re-adjusted the clamps several times and tightened the dog **** out of them, they still leak. Any suggestions?
Hookedup87
Long Island
The Flowmasters are notorious for sub par quality clamps if I recall. I would buy new clamps as well as some of that exhaust paste they sell. Take everything apart, if possible, put the paste on ends of muffler and tailpipes, slide back together, tighten up new clamps, you should be good.
GMcD
GMcD
South Carolina
i think you might be right about getting new clamps, but i don’t think its the clamps fault. I took some pictures of the backside of the outlets, and it looks like Flowmaster put a cut to allow the flange to separate when the rear tail pipes are inserted. To me, this cut goes too far back and the included clamps arent wide enough to squeeze the flange completely tight.
hawsk99gt
North GA Mountains
Express 2016
I just installed Flowmaster American Thunder on my 2016 RAM 1500 and I was wondering is it normal for the passenger side tail pipe to exhaust harder than the driver side exhaust, while idle?
NJMOPAR
Older and faster
ELizabeth, NJ
This is why I took mine to Meineke and had them weld it in. They had to remove right rear tire to get in & weld the tops. $100 well spent.
aimcgma
