Fog lamps
Rlaf75
East Hartford CT
2021 Bighorn
Is there an easy way to have the fog/driving lights stay on with the high beams? I know its law that the fog lights turn off with the high beam on but where I travel there's a lot of wooded area's that have alot of deer that pop out. I would like to have the extra light to help avoid Bambi.
R.L.K.
Bristol , Tn.
Some tuners have this option on the 2013+ , for your 2011 there is a way .
I haven't done it but some have .
It's pretty easy from what I've read .
Couple relays and some wire routing .
Post this up in Audio & electronics or Engine and Performance. You'll get more hits .
At one time CuylerTech with the Harness Connection was gonna make a kit for this .
Maybe search the above mentioned catagories for fogs with high beams ....
Andy578
Ontario, Canada
2014 Outdoorsman
honestly you'd be better off just getting a light bar. far more effective and they don't really cost all that much. i've seen some pics around here where people have mounted them in the grill so it's tucked away
Stlram81
Had one on my f150. Easy install, guy who sells them will help if you call. Worked good. Just got my Ram last week, one of the first things I ordered
Sent from my SM-G900V using Tapatalk
Rlaf75
Rlaf75
East Hartford CT
2021 Bighorn
Does that kit require you to cut factory wires? How does I hook up?
Stlram81
Nope. Comes with everything needed. Runs a fused +12 to the battery. (so there's no extra strain on the wireing) Grounds to the truck frame. And has a quick splice (snap on connector) that goes on the high beam power wire to toggle a relay to turn the fogs on with the highs. (When highs are on, fogs are powered directly from the battery)
Stlram81
Took longer to get the headlight out of my ford than it did to wire up. I believe they are specifically built for each application. Don't hold me to that though. The wires on the one I did were the perfect length.
Stlram81
I'll report back once I get mine installed on the Ram.
Stlram81
Will do. Definitely worth $20
Stlram81
Shipped today. Maybe a weekend project weather permitting
Reticle918
