Fog Light cubes
2010 Infantry Vet
Butler pennsylvania
Ok now that I know I can fit two 3" pods in my fog light holes on my go rhino bumper, I'm thinking one flood, and one spot pod in each fog light hole. Think I have it narrowed down to Oz and Rigid. Both have the smoked lenses i like.
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
I put the rigid Radiance on mine they look great. I have the hammerhead on my toy1ac027b8b5574f35eac3ebf40f0ef38d.jpg
Do your rigids have smoked lenses?
I highly suggest a smittybilt aluminum shackle mount. They are about $68 and give a much cleaner look. I just ordered it for my winch. That way you don't have to tie a hook into a shackle mount.
naumaa1
Colorado
IMO, go rigid and don't look back... I've played with the cheaper lights for years, and only recently started playing with rigid, they are superior in every way.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
I don't believe Rigid makes a flood cube in the midnight series, hence why im going to get a set of Oz and rigid.
sbarron
Wasilla, Alaska
Rather that the flood pattern, don't overlook the Rigid hi/lo cubes. While they take a little more to wire them up, having the dual brightness is nice and I think you'll find the driving beam pattern more useful.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Do they make these with tinted lenses?
Kapt
3L
Off topic, but I'm curious what the license plate means
8732cuts
US
CLIPPERKING...a barbershop in Northwest Houston
rwwells
East Coast
Hi 8732cuts,
What kind of brackets did you use to mount the Rigid Fogs? I also have a hammerhead bumper and mounted Rigid Fogs, but I had to fabricate brackets because the ones that came with the lights were too tall. I have a second pair to mount and was wondering how you did it?
Thanks
8732cuts
US
Hi 8732cuts,
Thanks
My bumper had a slot where you mount the cubes the rigid had the mounting screw attached like they where made for each other. Let's see your rig
rwwells
East Coast
Hi 8732cuts, My bumper has the same cutouts, but I installed Rigid fogs that have a wide flat beam. If I installed them completely behind the bumper it would block one side of the beam. I had to install them half-in half-out if that makes any sense. Is there a "how-to" somewhere on posting pictures?
8732cuts
US
I have about a 1/4" sticking out in mine. So they can sit level in the holes. Look close the cube is sitting on the lip of the hole. I used some 1/4-20 washers till I could get them levelc6960fd6e27d9b94604b0fd2b4b06051.jpg0d9ffff5d74975ff03fd95d9dadcea54.jpg0cc22d43869be178e328887a45341ae1.jpg6d1c4ed13bd1fae87479716d77fe1591.jpg
8732cuts
US
When you do you post there's a box with add symbol under where your texting... use that to post pics
joshhhh
