LoneWolf3574
I've been trying to find a slow coolant leak on my truck for about 6 months now. Well, I finally found it when I went under it to chase out the grounding strap from the heads and noticed a green (I added fluorescent dye to the coolant) wet spot along the length of the oil pan and block gasket seam. I traced it back to the front of the engine and found it running down the mating surfaces of the block and timing cover, top to bottom.
I plan on keeping an eye on it, for now, doing some research to see what it takes and how much will cost. Now on to the meat of my question, with nearly 172k miles on the truck, is there anything else I should look at doing? Right now I'm looking at replacing the timing set (chain, sprockets, and tensioner) since I'll already have it torn down that far. I already replaced the water pump, fan clutch, thermostat, and temperature probe this past summer. My dad is suggesting the connecting rod bearings since they'll be easy to get to with the oil pan out of the way and not to worry about the oil pump if there are no obvious signs of abnormal wear.
I'm not looking to beef up the bottom end for more power, only get more life out of the engine since I already have things out of the way.
