FoxBox has been shipped!!!
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
well finaly after 3 weeks, my dual 10" has been shipped, and now i have to go back to camp for work,bummer, anyways it'll be something to look forward to when i get home.
will update the install in 2 weeks!
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
what are you guys using to seal the sub to the fox box, cause i was told that the box is sprayed with bed liner,no carpet.
Alex
Weyburn, SK, Canada
2015 Mustang GT
When I did the subs in my car there was a rubber/foam ring on the back of the mounting ring of the sub, seemed like that was enough to seal it together, as I never had a problem with air leaking around the sub face, even though my box was just painted MDF. Once the screws were tightened down, it made a nice tight seal
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
back of sub 'should' have seal, don't use anything on the woofer it's self, could void warranty.
Low2HighRise
The instructions recommend using silicone caulk to seal it
Alex
Weyburn, SK, Canada
2015 Mustang GT
Really? When I was doing my car subs, the pamphlet that came with em said not to use silicone, as the fumes would damage the rubber surround
Low2HighRise
I may have misunderstood the question. The fox box comes in too pieces you silicone those not the subs, sorry
pd298
SE Oklahoma
You silicone the pods onto the frame of the box. Do not put silicone on your speakers. After you silicone the pods be sure and let it have time to set. You dont want to get silicone on the inside of your truck!
The subs should come with some sort of seal.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
you guys know what type (brand) silicone do i use?
and do i use screws too? if so can i use course drywall screws? how long?
my 10c104 kicker sub has some sort of seal build on the sub.
Graygoose
Oklahoma
Convert, for now.
small
clear silicon will be fine.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
FedEx said my box will be here in the AM :headbang:
i really don't know what type of silicone to use for the pods? any ideas?
and i wanna wire the 2 subs together for a 2ohm. has anyone drilled a hole in the middle of the box to run the wire from sub 2 sub? then just use one of the speaker terminals to the amp?
audio1der
Airdrie, Alberta
Pretty much any silicone will work; jusy give it time to cure before you start pounding haha
I like the drill hole between/run 1 wire idea; just put some silicone on both side of the hole after you pass the wire through to seal it.
Marc1982443
Southern Maryland
2012 big horn cc
couldn't you get the same 2ohm load using the speaker terminals on the box vs drilling through the box? might be a lil easier to accomplish.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
so fed ex dropped off 1 box. the box with my pods/screws and stuff are sitting in memphis TN, due to inproper paperwork, thanks joe. anyway it will be here march 4. this sucks.
BIGBLACKHEMI
Jersey
No good.. I'm just gonna have my shop build me a box...
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
so package Number 2 has just left troutdale OR. be here march 5.
can't wait. does your back seat flip down with the spacers?
Marc1982443
Southern Maryland
2012 big horn cc
Yea it does. On the passenger side no need to take center seatbelt bolt out. Just remove the 4 holding the seat down lift one side set it on spacer. Then do other side. You will know what I'm talking about when you start pulling it a part.
gville35
