Frame
2515x3jj
Newport, Pa
Hello. I would like to know if anyone can help with info on my 03 2500 5.7l auto 4door 6.5bed frame. Seeking a used one because the amount of work needed to restore this is not worth it to me. Question is : What years and models can be used. Any info would be greatly appreciated, and any info on prep , paint, and a rust preventer? Thank you
2515x3jj
Newport, Pa
Mr. grpht03ram, Thank you very much for you time and efforts, I do hope it will help me.
2515x3jj
Newport, Pa
unfortunately it will not open for me, thank you anyway.
grpht03ram
You can't open the picture?
I didn't attach the entire parts document
just that picture that shows the only two part numbers for 6.5' bed
tron67j
Maryland
Before buying any frame parts make sure you get it placed on a frame jig and ensure it is true. Very expensive to fix one, but it can be done and done very well. If you want to clean it and paint it I suggest a water sandblaster with an additive that will prevent rust from immediately forming, but you have to coat frame quickly. For the frame, a good powder coating is what I recommend at a reputable shop. Good luck
