Front CV Axle Castle Nut
Seth_5.7
North Carolina
Quick question because I'm in class right now, what size is the Axle nut on the front cv's, and what is the best way to loosen, and tighten it. (I will be using a breaker bar rather than a impact).
Need to get it off so the LCA isn't hanging on the axle boot when I have everything else off painting it.
troy rowe
manitoba canada
Many people report its 35mm-so I went and bought a 30 dollar socket and turns out its a 36mm_NICE
Seth_5.7
Seth_5.7
North Carolina
Thank you for your 30$ sacrifice [emoji23], I should have a 35mm laying around somewhere and I'll test it when I get to it, if it doesn't work I'll be buying a 36mm
Sent from my SM-G920P using Tapatalk
