Front end alignment questions??
Trykonkid11
New Jersey
I had the spacer lift in my truck and changed it out for the Blistein shocks and set them at 2.8. It leveled the truck with a 1/2 inch rack. I had the truck aligned after the spacers were installed. Now my question is (which I think I know the answer to, Yes) should I get an alignment again? The front does not look pigeon toed at all. What do you guys/gals think.
I searched for this topic but came up empty. Any input would be great. I'm kinda hoping I don't have too.
Isaac5108
Washington
Cummins 6.7
Probably didn't change much. But I'd still recommend getting it checked anyway. Cheap insurance if you ask me
Luxuryram10
Aurora ohio
I would most definitely get it checked. When I got my 10 1500 leveled it shot my camber way out. So far out I had to buy adjusting balljoints to compensate how far out it was.
quietpeen
2021 TRX
Hellcat
Yes, always need an algnament when making any changes to the front end
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Get it aligned, you may not notice while driving, but you'll see the wear on the tires. It doesn't take much for the alignment to be out to wear the tires wrong.
Isaac5108
Washington
Cummins 6.7
Cost of an Alignment is a lot less than a set of tires! Like I said before, cheap insurance!
Trykonkid11
Trykonkid11
New Jersey
Ok, that's what I thought, just wanted to make sure. Thanks for all the replies, much appreciated.
novelmike
Central California
When I made the switch from Rancho quicklift to Fox 2.0 shocks I waited about a month or two before I had it aligned. There is a small, independent shop I like in North Hollywood, Ca that I like. And it just difficult to get in there with my schedule. ANYWAYS.....it was a little out of spec and it made a big difference in the way the truck handles. Feels a lot better now. The alignment was great before the Fox's were installed. And the Fox shocks only raised it about an inch. But that was enough to throw it out of spec and effect the bumps, dips, etc. Even though it still drove straight down the road!
I think people just figure alignment is for tire wear. But a alignment that's out of spec effects the way your vehicle handles too.
novelmike
Central California
joshhhh
