Front Leveling kit and towing
Ktstull
HEMI 5.7
Has anyone put on a front leveling kit and then towed with their truck? I've got a 6500 lb camper to tow, just wondering if it will make the back end squat or not?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
It partially depends on your towing setup (WD hitch etc) however yes, it is likely your truck is going to squat. This can be reduced with a set of Airlift 1000 bags or if you wanted to go full out, Airlift 5000 bags. The Airlift 1000 bags will be adequate for this application though. And all that being said, a little squat isn't something to be overly concerned about. My truck sits dead level with my lift kit. When I throw 10,000 lbs on the back it definitely squats but still tows like a beast.
BoldAdventure
Airstream, USA
FWIW, I did the Bilstiens 5100's at 2.8 on my Ram 1500 and added the Tuff Trucks springs the rear. Across the scales the trailer was 6900 something.
Ktstull
Ktstull
HEMI 5.7
Yea, I'm not too worried about the towing abilities, the capacity on it is 8650 lbs. Honestly just wondering how it will look. Know what I'm sayin'?
Ktstull
Ktstull
HEMI 5.7
But if the the airbags will help the look plus give me a little more towing ability, I'll look into that!
brandonjansen
Here's a picture of my old 1500. 2.5" front leveling kit, 0.75" rear spacers and Airlift 1000 bags, no WD hitch. Total trailer weight was probably around 4600 lbs. It sat pretty much level.
Some squat doesn't necessarily look bad. Here's my current truck pulling +/- 10,000 lbs with a lot of tongue weight.
Ktstull
Ktstull
HEMI 5.7
How easily are your Bilstiens adjusted? I know they're ride height adjustable, but does that mean you can change it whenever..... Or is it a headache to do?
muttmutt
2016 Ram Sport
You have to remove the entire strut to change them and then get another alignment. They are really designed for a 1 time adjustment based on your liking.
Ktstull
Ktstull
HEMI 5.7
@muttmutt thank you!
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
this is at 2.1 and no air in bags. I have heavier springs
