Front Park Sensor vs Brush Guard
RAM Gramps
Austin, TX
3L I6 Twin Turbo
Hi All. Installed a Ranch Hand brush guard on 2025 1500 with parking assist. Now the front sensors alert intermittently. The way they alert would suggest the sensors are getting reflections from the lower frame of the guard. The frame does not block the sensors, but the sensors sit just inside the flat vertical frames of the guard. It could be possible that sensor signals are being errantly reflected by the steel framing creating false inputs. Has anyone else experienced this? I like the front sensor assist, and would like to continue using them. Could there be some kind of coating or padding I could install over the frame that would absorb the signal at the frame thereby preventing any errant reflections? Thanks!
STL Missouri
I have the same problem with my brush guard. At first I thought I'd mixed up the sensors or messed up the installation, but that wasn't the problem. They are just a little too sensitive and still "see" my brush guard even though they are all the way forward. Nothing I've found can solve it so far.
