Front plate brackets
RandomRam
On the Oregon Trail
Is anyone using anything other than the factory front plate bracket? I put the air dam back on after leveling, running self tappers into it from the factory bracket seems pretty janky.
OC455
Central NY
I used longer screws and nylock nuts with a washer on the back side. The plastic license plate bracket where the machine screws went through were not holding well anymore.
RandomRam
RandomRam
On the Oregon Trail
Yeah the factory setup is pretty janky for an otherwise stout truck. Not as janky as Toyota where you shoot a couple self tappers in the bumper to hold the front plate on, but still lacking. I might try that out.
OC455
Central NY
I think the screws I used were an inch and half long with the nylock nuts. Trying to remember if they were M8's....they were metric the ones I used.
