Front shocks help
zwarren6
madison, mississippi
So today I was wondering what size blocks were in the rear of my ram 1500. I measured them to be 3in. I found a website that is selling 5 1/2in blocks for $95 and I thought it was a pretty good deal. My truck is already leveled 2in in the front. If I get the 5 1/2in blocks it will make my truck un level. Anybody know of any inexpensive way to level it back out? whether it be shocks or coil springs? thanks
Johnn123
Ontario
Get add a leaves instead of a bigger block. Bigger blocks cause axle wrap, leaf springs do not :)
But after that ya longer coil springs for the front, then you will need longer shocks front AND rear. As well as an adjustable track bar, new control arms if you want to go over 2 1/2" of front lift. Longer pitman arm after 3 1/2" IIRC. Also you may not be able to reuse your coil spacer with the lift spring. Lot of debate around that though.
joshhhh
