Front Stabilizer Bar
quasarn01
Dandridge, TN
My front stabilizer bar on my 2013 Ram 5.7 4WD Tradesman has split on the ends so I copied the part number from the tag on the bar and I tried to find part number anywhere on the web but to no avail. It's 5154683AB but apparently that part number has been retired for a while. Is there a site somewhere that I can cross reference that part number so I can match it up and order another front stabilizer bar?
pacofortacos
while you can't cross the part number, you probably can find a replacement at car-part.com
I would measure the OD of your current bar just in case there are several different diameter option.
Q
quasarn01
Dandridge, TN
I checked my area and there were a few 1500s in the Knoxville area so I may take a run out there to check. The bar itself is 1 7/16 inch thick. Kinda hefty compared to the ones I found online ranging from 1 1/16 to 1 and 1/8...
hunterdan
SE PA
2019 classic
Have you tried looking up any of these numbers?
Q
quasarn01
Dandridge, TN
Thanks for the info... I've looked at all of the above part numbers so I'll go back to one of the Mopar sites and use my VIN and hopefully find the correct bar...
ChloeBrooks
