Front tow hooks for 22 Ram Classic Warlock....DT or DS style? Also, where to buy.
Tifford
Central NY
3.6 V6
Need info on adding front tow hooks to my Ram Classic Warlock 2022 with the 3.6 pentastar engine. I believe the dealership wanted over $500 for theirs. Trying to save money and go the aftermarket route.
1) Is it the "DS" style or the "DT" version that I need?
2) What years are interchangeable with my 2022 Ram Classic Warlock?
Any links to a used or China clone would be helpful.
Thanks
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
The 2019 thru 2024 Ram 1500 Classics are all 4th gens (DS). You should be able to use tow hooks for 2013 thru 2018 Ram 1500, or 2019 thru 2024 Ram 1500 Classic. Last time I checked there were plenty on ebay if you don't want to go through a dealership. Or used from a junkyard.
T
Tifford
Central NY
3.6 V6
Thank You!
ramman95
Blackwood, NJ
2015 Ram 1500 Limited Crew Cab 6'4" Bed
5.7L Hemi 4X4
Go to eBay or amazon and search for 82210967. You'll find plenty of cheap aftermarket tow hook kits (open loop) for around $100. If you want used OEM tow hooks (open loop), the parts numbers are 55398284AA 55398285AA. The part number for the OEM Rebel/Warlock tow hooks (closed loop) is 68248844AA, apparently both sides are the same.
Dean2
Near Edmonton
Warlock Specific Tow Hook set parts numbers
Update your Ram 1500 DS Rebel or Warlock with this front tow hook kit. Same as production.
This kit is specific for Rebel and Warlock models only.
Kit Includes:
  • 68248844AA x2 Tow Hooks
  • 6104454AA x2 Bolts
  • 68271565AA Bezel Kit (Includes Two Bezels)
jason1
US
Has anyone tried these?
Doesn't look like the warlock style. I picked up what Dean2 listed above and worked perfectly.
hunterdan
SE PA
2019 classic
Those cheap Chinese ones will rust and the finish flake off pretty quickly.
So, if you get them, I'd suggest taking them right to a powdercoater and getting them done. Was only about $75 to have mine blasted and coated. Don't need to go with orange like me, but I like the way it looks. And they're coated with a base and a clear, so should be pretty durable.
Johnnguyen6596
