Fuel Pump Assembly for 2016 Ram 1500
n8mojo
Roseville, CA
Hi Benny,
2016 RAM 1500 5.7 HEMI VIN 1C6RR6FT1GS193671
I replaced fuel pump with Delphi due to failed fuel sensor. 2 weeks later, car doesn't start and throws a p018d. Starts later in the day. Works for awhile then does the same thing. Thinking the aftermarket part is garbage.
Can you confirm OE parts that are needed: 68092755AA and 68092755AA
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi,
Here are links to the required parts
Note that the pump is on backorder and will take a few weeks to get. I will send a code you can use
Thanks,
- Benny
