Fuel pumps???
EMK
2008 Bighorn
Why are the 34 gallon tank pumps different than the 26 gallon pumps?
E
EMK
2008 Bighorn
I have a pump out of a 34 gallon and mine from a 26. Mines a Mopar pump and not sure what the 34 brand is. Side by side comparisons the dimensions are the same. The float on my 26 is on the drivers side and the 34 float is on the passenger side. The wiring on the pumps are identical and the fuel inlets are the same. Why can't you use either one?
E
EMK
2008 Bighorn
Well the 34 gallon pump is in and working fine. Had a half tank when it died,and its reading a half tank after the install.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Well done.. I couldn't see why they are different but then when looking at pcm numbers, they have a different pcm number for different tank sizes. .. go figure..
