Fuel sending unit questions
D150dude
Ontario,Canada
Stupid question here. I’m having a tuff problem trying to find a sending unit for my 81 I want to be driving this truck not oooking at in the driveway. Can I replace it with a newer model one say from a late 80s early 90s?
crazzywolfie
under the truck
81-87 is what sending units should fit. they are still readily available at $100 unless you don't mind paying lmc's markup. 88-90 fuel sending units are unique and junk. the 91-93 sending units are better but require a completely different tank to use them and even them they got an electric fuel pump that puts out way more pressure than your truck needs for a carb
http://www.521restorations.com/index.pl?page=Truck/Van&sub1=Fuel
D150dude
D150dude
Ontario,Canada
Where’s a good place to find a sending unit? The local places around me can’t find them from there distributors and some people don’t understand what a sending unit is
stimpy433
IOWA
Order it from rockauto.com, they should have it.
crazzywolfie
under the truck
nope
you could try a dodge dealer but you need to bring them a part number. the link i posted has them also
Sending Unit - 5/16
1981-1987 Dodge Truck - 5/16 inch stainless fuel tank sending unit with strainer. Fits models with 20gal fuel tank. The overall length of this unit from filter sock end to the top edge of the face is 20 7/8". Replacement for 4075252, 4075378, and 4051889.
Part No: FG8187T20
$99.95
Sending Unit - 5/16
1981-1987 Dodge Truck - 5/16 inch stainless fuel tank sending unit with strainer. Fits models with 30gal fuel tank. The overall length of this unit from filter sock end to the top edge of the face is 24 3/4". Replacement for 4075254, 4075380, and 4051891.
Part No: FG8187T30
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
only other place I've seen them is ebay.
https://www.ebay.com/itm/NEW-1981-8...401616315596?_trksid=p2385738.m4383.l4275.c10
getting parts for these old trucks is a pain in the ****!
I gave up and decided to go EFI. I guess that's trading $$ for headache. I lucked out and got my hands on a free 93 30 gallon tank off CL to go with the 92 22 gallon tank I already had. then got a screaming deal on Bosch 67611 pump/assembly for $70 each on amazon. Usually more like $170 everywhere else.
Flat black
No where
Cummins 5.9
I have a 1990 dodge cummins and I had sending unit issues so I put a tank on the back and just used a electric fuel pump that costs 40 dollars roughly and wired it to a switch in the cab and the battery and I'm rolling again
