FUEL soaked ECU connections.
Kevin Schilling
North Carolina
Had a CP3 leak that soaked the engine compartment.
Ordered and installed a Fleece 10mm stroker and was rolling coal at idle and sending more codes than I could count.
After numerous hours of checking things, I pulled one the ECU connections and found diesel pooled inside. So much for being sealed.
Cleaned them with electric circuit cleaner and blew them out with air. Hopefully this will fix, but I m thinking the ECU is toast. I know tomorrow
