Fuel System Upgrade Ideas/Questions
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
VA, the 50# injectors your talking about. Is that rated at 43.5 psi, or rated at what our trucks put out... what is out psi anyway. I know you said it's higher.
Trup,
I'm going to assume they are rated at 3bar as they came from a supercharged truck. I asked him what his horsepower was and haven't checked back. My last PM looked like it went through to you with the address.
Trupiano
Trupiano
Registered User
6.7L CTD
I was using your calculator that you sent me and it basically says his are rated for 550 crank HP if they are rated @ 43.5 psi. Now I just need to know what psi he's rating the 50#'s off. I was looking for anywhere between 550-600 for now, so that should be perfect. I'll have to scrape some money together and scoop them up. Thanks again VA!!!
Steve Holtz
