Fuel tank?
Dnormz311
Mentor Ohio
Hey guys question for you? I have a 2019 ram 1500 with a 5.7l. It had the 24 gallon tank and I swapped it for the factory 33 gallon tank. Fuel pump and sender is the same part number for both so I used the old pump. When I fill up truck now the range till empty says around 350 which is what is said before and the gas needle works but only for around 350miles then the low fuel light comes on. When I go to fill it up in only takes about 20 gallons so I know there’s more in the tank. Any idea how to relearn the truck ecu or program it? Thanks.
Dinky
Oregon
Alfaobd. I don't know what settings need to be changed but I know people have done it.
Search here.
sounds like a simple software change
look into the ALFAOBD software programmer
check into the options that it can change
runamuck
dfw
6.7 dsl
a software thing. my '19 laramie 1500 4x4 5.7 3.92 ccsb would often show over 600 mile range after a fill up.
Joey93
