fuel tank
  1. 0
    Rattle in 4th gen gasoline fuel tank
    With the truck off and not running, and if I use the palm of my hand and hit the plastic fuel tank like a drum, something inside is rattling. Anyone else experience this and if so, then what was rattling? Part of the fuel module, baffle come loose if it has any, something in the fuel tank...
  2. d_giessel
    Fuel pump voltage and diagrams for 2016 6.4L
    I'm looking for technical info on the fuel pump. I'd like to see a wiring diagram, and I'd like to know how much voltage (and from which port) I should be getting to the fuel pump. I am diagnosing the crank-but-no-start issue on my truck. (2016 6.4L) Up to this point, I have a new battery, new...
  3. P
    Broken vapor canister lines
    my fuel tank straps failed and the tank fell off the other day while driving. I got it back up and strapped but now the truck sounds like it’s sucking in a ton of air when accelerating. Here are some picture of the broken piece. Any help on where I can find a replacement or cheap fix or even...
  4. D
    Fuel tank?
    Hey guys question for you? I have a 2019 ram 1500 with a 5.7l. It had the 24 gallon tank and I swapped it for the factory 33 gallon tank. Fuel pump and sender is the same part number for both so I used the old pump. When I fill up truck now the range till empty says around 350 which is what is...
  5. J
    Auxiliary gas tank
    I have a 2021 Ram 1500 Big Horn Hemi, looking for information if anybody has installed a gasoline auxiliary fuel tank in the truck bed. I had one in my previous diesel but I am unsure about the volatility of gasoline in the truck bed tank. I had was a complete enclosed unit with the filler neck...
  6. S
    Mystery part in fuel tank
    Hey guys I’ve been having some fuel pump issues on my 2012 ram 2500 5.7 hemi (ran a fuel pressure test and had about 10 psi and very quick bleed back) and dropped my tank and pulled my pump and when I pulled the pump I found this part at the bottom of the tank, compared to the new pump, doesn’t...
  7. patrickocake
    crack in fuel tank
    I had a crack in my fuel tank. I used a soldering iron to melt the crack together and JB welded the outside of the tank to make sure it doesn't leak. Any thoughts?
  8. Brando_SLT
    Leaky Gas Tank - Easy Access?
    Hey Guys (and Gals), I have a bit of a leaky gas tank and need to address it. About 4 months ago I had a new fuel pump installed at a shop, it's been over 90 days so it's too late to have them take a look at it. I am thinking it's a bad filler hose (I have a replacement), or possibly the o-ring...
  9. R
    Titan Fuel Tank
    Just got my Titan Fuel Tank! Excited to actually be able to pull my trailer without stopping all of the time. Going to do the install this week so i will let everyone know how it goes! anyone know about these tanks?
  10. JDA-PW2018
    Bigger fuel tank options?
    Love my '18 power wagon. It's a tank and gets tank like MPG. That in of itself doesn't bother me. But with a 31 gal tank @10mpg, that's ~300 miles range. Not an issue when there is a gas station all around, but on long trips off-roading, where it can get down to 3mpg, I do get some range...
  11. R
    Need gas tank!
    This is a long shot, but need some help. Have to replace the gas tank on my beast. Ideas on places to contact near Delaware or places that will ship. Sucks big time. 1996 2500 V-10 4X4 EXT cab. Thanks in advance!!!!
