Fueling issues
Eli44
Vermont
HEMI 6.4
I have a 2017 Ram 2500. It was recently giving small evap leak codes, I replaced the purge valve and that fixed that issue, but now every time I fuel up, the pump clicks off after 2-3 seconds. Occasionally if I get it with full pressure it will pump just fine. Reading other post's, I have looked at the vent tube and don’t see any obvious kinks. I have not disconnected it yet to blow out possible blockage. I’m wondering if the purge valve could cause this, or could it just be a coincidence that this happened soon after replacing the valve?
