Fully Loaded
sandsailor1
6.7 CTD
So when is the last time you actually put 3/4 of a ton in the bed of your truck? Ever tried?
Well, I currently have one pallet, 75 bags, of mulch in the bed of the truck, that officially weighed in at 1495lbs.
So here is the result, it squats real low in the back, enough that the steering becomes a little fuzzy. I had them push the pallet as far forward as they could, I would say center of the pallet is forward of the axle by six inches. So besides the truck sitting front end high and the steering a little fuzzy, it rode real smooth.
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
In my 1/2 ton I've hauled pallets of salt and they weigh 2450 pounds
Sent from my SCH-R970 using Tapatalk
S
sandsailor1
6.7 CTD
Yeah, I was not real happy with how much that one pallet squatted the truck in the rear. I have hauled more with my other trucks with less squat. I think it may be the change from leaf spring to coil springs in the rear.
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
Yeah I I've got an 06 font have the coils and I have bags to help it. I plan on put 3/4 ton leaf springs in this year
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
I haul 1 ton pallets of pellets in my truck all winter. This year I convinced myself to put a set of Firestone bags in the rear. Now I load the pallet, air up the bags and it sets perfectly level. Next step may be to put an on-board compressor so I can set the bags with the touch of a button.
Power247
High Point, NC
6.4 HEMI
The new coil springs give much more than the leaf spring setup. If you are going to haul heavy often the a set of airbags are almost a must.
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
The bags make a lot of difference hauling or pulling a trailer
S
sandsailor1
6.7 CTD
Yup, pretty much convinced I need some bags in the rear. I have a small pump in the garage I will set up as an on board compressor.
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
That should help you out a lot I'm going to be putting 3/4 ton leave Springs in this year but I haul all the time
