gauge cluster problems
mbtech
Hi there,
I recently acquired a 2004 1500 ram and am having some issues with the instrument panel. The gauges all appear to be working, with one small problem, they all appear to be rotated too much clockwise.....i know, seems odd, but the speedometer starts at 40 km/hr (the gauge still reads correctly in that when i am doing 100km/hr it reads 140 km/hr), the temp gauge reads warm when it is for sure cold, and everything else is off to the right as well.
I tried the simple gauge check (trip meter in, turn on key, release trip meter) and they go through the checks. Funny thing is the speedo goes way off scale and when its done returns to the 40 km/hr marker....odd.
Has anyone else ran into this issue, and if so is there a quick fix or is a replacement cluster the only option.
Thanks,
Luke
HemiLonestar
Navy Badge Coast Guard
MD
There is a diagnostic that can be done to check/calibrate the electro-mechanical gauge cluster (what the factory calls it). Unfortunately you need a DRBIII to do it. So it's either a dealer or a mechanic who has a DRBIII. If you are in close proximity to the SE corner of NC I can do it (but not until I get back from patrol next month).
M.Varner
Magnum 5.2
I have a question that probably doesnt have anything to do with what yall are talking about but I was wondering if I could take the instrument cluster/ Speedometer from a 04 05 ram truck and hook it up in my truck of if I could make it work in it.
